i have a seadoo hx from1996 and it wont start, it tries to start but just wont turn over. i checked for a spark on my new calibrated spark plugs and there was none. i think its the ignition coil. what do you think?
Does it not turn over, or it won't start? If it turns over but won't fire up...do these tests; Check the continuity of the Safety Switch Lanyard. It is normally "open". The color codes of the 2 wires are Black and Black/Yellow. These feed back into the electrical module box. The Start /Stop switch is normally "open". The color codes of the 2 wires are Black, that goes direct to ground, (to stop the engine), and the Yellow/Red that goes to the electrical module box. Check the continuity of this switch too.
If all checks out ok, I would check the ground on the ignition coil so that it has a good connection to the grounding point.
