New member here - very thankful for all advice.
I purchased a 2004 Wake 155 from original owner last week. PO maintained it immaculately; only 76 total hours and looks new. I expected no issues, but finally got it to lake yesterday and had some. Ski started and ran fine for a few minutes, but at a lower than expected RPM. I am using the correct key. Pulling in to the dock, ski wants to cut off. Will not idle good.
Went to re-start and ride kids around and ski is slow to crank. Tried it a few times and battery discharged too much, so I pulled cables off and hooked up a charger for 15 minutes. Ski started right up and proceeded to run OK, but still at a slow RPM. Then the 12V low voltage alarm light came on. Ski would run about 35 MPH and ran quite well. A few times, the ski would surge forward to about 55 MPH, like I believe it should. But, it would only stay there for a few seconds, then drop back to 35. As a conservative measure, we shut it down after only about 10 minutes of running and put it back on the trailer. Needless to say, kids were none too happy after driving 1.5 hours to learn to ski.
I spoke to PO this morning and here is the current situation:
Battery is new this June, from O-Reilly's. Is a maint-free gel type. He had seen the low voltage alarm earlier this year, but it went away after he rode a while so he assumed charging system worked properly to charge the battery.
As for the speed limitation and surging. He says the gas may be a bit stale. The symptoms I experienced fit the tune of old/stale gas perfectly. There was about 7-8 gallons in when I bought and I added another 5 new yesterday before we hit the lake.
Questions:
1) Should I remove and charge the battery and then have load tested?
2) Should I check charging system before I remove, and how?
3) Would the low voltage possibly cause the low RPM/surging I experienced?
4) Should I remove and replace fuel? How best method?
5) Should I add some fuel injector cleaner to a new tank of fuel?
6) Is there a fuel filter?
I have always done all of my own vehicle maintenance; some of it very extensive, and would like to do all this myself. I have accessed the manual and am very excited about having my first jet ski and my 2 kids are even more excited. I just want to make sure I head down the correct path with all the experience you all can offer.
Again, thank you very much for any help you can offer.
David
Questions:
David
