Hey all,
My friend has Utopia 205 with 240 EFI. His boat would not start this season, so after a rather unpleasant encounter with an unscrupulous mechanic who immediately decided a new engine block is needed (seriously?!? no diagnostics), he got the boat back and after going through threads here and in the service manual we have isolated the problem to be a fault Crank Position sensor as it reads 0 on the ohmmeter (320 normal) and no spark at the plugs.
At any rate, new CPS is on it's way however we are having a hard time removing the bolts holding the CPS in place. They seem to be 8mm metric bolts as 16/52 did not work. It is a very tight space and I was wondering if anyone figured out what WRENCH works as flex wrenches are too thick in the ring and stuby`s may not have enough of an arm. He has been back and forth from Home Depot (I am not around today to play with it). I don't want to reinvent the wheel on this one, and removing the FLYWHEEL is not something that we want to get into (to get a socket wrench in)... any ideas would be appreciated, I have been thinking of getting a Bionic Grip to get in there....
Thanks
Thanks
