abnwayne
So I just picked up a new to me utopia. Seller told me he lost compression on 2 cylinders one with 0 and another had 20 psi. The seller described everything to me that sounds like a lean seize. upon checking the case for holes we settled on a price and i bought it. most of my experience being with the rotax powered engines this will be a bit different for me as its the 200 optimax engine upon initial teardown it definitely looks like a lean seize
The picture is a bit blurry but number 4 melted the piston and number 6 had stuck a ring
So as of right now i dropped the block off at the machine shop and have dug around looking for what caused the lean condition on this boat and i find this...
that is the injector four number 4 i disassembled the rails and proceeded to clean them out i will end up sending my injectors out to be flowed and cleaned the price of these injectors are crazy!!!!!
i proceeded to do a bit more digging and disassembled my air compressor but did not find anything damaged or broken inside it the piston looked good in it with no visible scoring on the walls and tearing into the bottom end showed no visible signs of bearing damage. if anyone wants to chime in here it would be beneficial on where this metal came from id be much appreciative becuase im looking and cant find anything as of yet.
i forgot and spaced to take pictures of the compressor but i do have one of the piston in it and it looks fine
