nascar991@bellsouth.net
Well, finally after 4yrs, numerous calls and many trips to a horrible dealer,Seadoo has agreed my boat is junk !!!!!!!!!
2006 sportster with 3.5 hrs after 4yrs.Cracked from stem to stern.broken Wake tower (at welds) pure junk!!!!!
What i have learned.if you really are honest and really dedicated to what`s right then here is what you need to do.
first thing is to go to (your selling dealer) as you will be treated poorly if you don`t.second thing is to be ready for your hair to fall out.... but i now know what it takes to be righted.DO IT YOURSELF !!!!! if your boat is junk and i mean junk then make a call to seadoo and start the prosess.what you will need is a pad,pen and time.once you make the call write down the complaint #,then ask for your rep that will handle your problem,.i.e. name and ext # of the rep in the tech dept.once you do recieve a call, be calm, cool and don`t ever yell, because you need to do everything you can not to go thru the phone an choke someone.get all information before you make your call. take your boat to an independent repair shop.make sure you deal with a shop that has really good rating.get a hand writing detailed report on your boat.also give your tech his or her shop # and person who inspected the boat,this will go along way to help.keep in contact with your seadoo rep call at least once a week fo updates and be prepared to explain all of issues from the time it started.if you do this you will have a pos outcome.but remember this, they use a BUDS sysyem to check your operations from the time it was started,DON`T LIE or it`s over.......Oh i forgot the best thing,new boat on it`s way !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
