In mid run last night my 2003 GTX RFI just came to a stop. It starts and runs/revs fine but no movement no wake nothing. Seems like it is in some sort of neutral or kinda like if a U Joint on a truck snapped? Any thoughts?
if you pull the seat off, is the drive shaft spinning? also if you start it out of the water is the prop spinning? If your prop is spinning, you have cavitation
You may have been in shallow water and sucked debris into the water intake. Could be rope wrapped around driveshaft, Baby diaper, plastic bag ect...ect...Bills
I am having trouble with my seadoo. I will start it up and go to take off and I will just get it reving high and no real movement it wont go past 10 mph and thats with reving it to the max. any suggestions?
