seadoo sportster le di fuel filter replacement question
silverbar
Planning to replace the fuel filter on my 2005 sportster le di , anything I need to know? its fuel injected and I assume pressurized, also is there any process for the start up after replacement?
thanks for any help
-Roger
Pull the fuel pump and replace the internal fuel filters. There will be two of them that can be purchased at any auto parts store. Airtex FS220, FS242.
You will need fuel injection line tools to remove the canister fuel filter as the hoses/filter are an all in one assembly. You can purchase the tools at the auto parts store as well.
I personally cut the filter off the hose and replace it with a Wix 33095 metal canister filter using two heavy duty stainless steel hose clamps.
Hope this helps.
