Seadoo sportster 2003 check engine light.
junjun
I went out last Saturday after long winter Chicago weather and after 15 min check engine light came on I turn off engine and re start everything's fine need help?....
Did it run fine the rest of the day......running 15 or more mins without stopping?
On my speedster, I had a light come on with the beeper, the engine would drop in rpms. If I stopped and took the dess key off and restarted it was off and fine but after some time it would happen again. Ended up being a oil sensor- at least I hope so, I replaced them but have not took it back out yet.
Yes it's run fine for almost 4hrs without stopping and went home. Engine are fine didn't drop rpm. I need to check the oil sensor! But I don't know where is it? Can you pls show me a picture? It's a big help to me!
You need the BUDS or CANDOO system to read the engine light code. Nothing you can visually see looking at the sensor. Could have been a random code that fixed itself or maybe a hr maint light?
invest with a candoo system, otherwise its very difficult to isolate the problem. you also need the manua.l upgrade your membership and download.
Thanks god boat was check and no problem at all! Boat engine have to much oil on it, I remove some and test the boat for almost 1.5 hr run and no more check engine.
