This is the only seadoo boat I have ever been in so I am not sure if this is normal.
I belive my 1998 seadoo sportser 1800 is having a slight cavitation out of the hole issue.
When pulling a skier, full throttle from a stop, it will hit the rev limiter for maybe 2-3 seconds until it planes out.
Is this normal or should I expect it to thrust forward right away and not hit the limiter.
I have replaced wear rings and have new scat trak high pitch impellers.
If this is not normal I guess I'll replace the carbon seals next.
I did just replace one bad rear motor mount but have not been back into the water to see it this helps.
Thanks,
-Kevin
Thanks,
-Kevin
