Seadoo Speedster Twin Engine '95 For Sale
Selling my Speedster! $4500. Excellent shape, just had it out Friday and still love this boat but can't keep two.
Bought it two years ago - originally titled in Michigan
14.5 foot length about 1200 lbs
Seats 4 rated for 750 lb load
2 - 80 hp Rotax 2-stoke motors - no Rave vales on these. 140 & 140 compression in Starboard engine, 137 & 138 in Port. Starts easy and runs perfect.
Both Tachs work.
Skat Trak impellers - no dings - really improves the hole shot - $500 new.
Aluminum reverse buckets.
Trim tabs on Transom - helps hole shot - planes quicker - rides smoother.
Work done this spring:
Washed and waxed, this boat shines!
Seats cleaned and conditioned with 303 Vinyl protectant.
Cleaned bilge.
Adjusted throttle cables.
Adjusted shift cables.
Changed Jet pump oil.
Greased Carrier bearings.
Greased trailer bearings
Replaced bunks on trailer with treated wood last summer.
Vinyl seats are in very good shape, not stained, soft, no sun burn. Two blemishes. I fixed a small hole on the port shoulder bolster and the repair color doesn't match. The front sun pad has a few small cracks on the front edge. I did use vinyl adhesive to keep them from spreading. I can send pictures of both. I will inculde the repair kit if you want to try it yourself.
Includes:
Seadoo trailer - all lights work.
Seadoo mooring cover - no rips.
Fire extinguisher
Manual
Air horn
Paddle
2 life jackets
The boat is very original, I don't think it was used much based on the condition. I haven't put many new parts on it becasue I simply haven't needed to. This boat looks good, runs good and is ready for the water. Everything is in great shape!
This is a cheap way to get into boating and have a lot of fun!
PM me if you're interested.
You can check out more details at http://wausau.craigslist.org/boa/1759973844.html
Both Tachs work.
Cleaned bilge.
Includes:
Fire extinguisher
Manual
Air horn
Paddle
2 life jackets
