Water sports
Have some more questions,
1- fuel filters are they ok mounted on a angle, ? see photo attached.
2-A Oil 3/32 small oil lines (Running from the oil pump to the manifold under the carburettor. question here is once removed do i fit a stainless hose clamp which is my preference or is it recommended to use a Cable tie.
2-B Fitting the new oil pipes 3/32 to the pump this looks to be very tight as the pumps are at the back side of the engine, any advice. ?
3- I have taken a photo of the oil pump and this is looking rusty a little, what is your advice, ? see photos attached.
4-what is this plug for, ? see photo attached.
5-In relation to bleeding and priming the petrol and oil system how do I get air into petrol tank. ?
6- oil bleeding I understand this is very critical and must be carried out correctly is there any further advice you could provide me to watch out for a was thinking about adding some oil to my petrol Temporary, just in case.
7- What typically is the hawk I gauge used for, see photo attached
8- how many buzzer's are on this boat.
9-is it recommended to remove the oil pumps for cleaning ?
