Seadoo speedster 787 jet boat
Water sports
Just wondering where the water gets sucked in threw the jet pumps and into the engine cooling system, as I want to make sure that this is not blocked I have replaced all water pipes throughout this is due to the alarm coming on continuously on the boat
it come in on the pump from the big hole make sure the orings are there
The three holes in the brass part of the pump in the pic are the cooling inlets. If your wear ring is bad it can create low pressure and poor water circulation.
Have you flushed the motor on the hose? You should have a strong stream coming out of the pisser by the tow hook. If not you have a blockage somewhere.
When flushing remember to never have water turned on with the motor off. Motor on, water on....water off, motor off
Well heres the rhing water does not pour out the pisser strong like a out board motor, mine just trickling out
