99spxxx
:thumbsup:Here is my full list of SeaDoo pumps. 155mm and 140mm from 89-2004. All have good bearings. Will write in if bearings are needed. Wear rings I will state that they are Good working condition, Recommended replace for best performance but will work, or must replace. Pm with any questions. All Prices include Shipping within the Lower 48 States.. Will ship anywhere else at customers expense.
Also if You need me to install new OEM wear rings I will do for an extra $80 each..
155mm pumps:
#1 Brass veins have a few small nicks/ recommend wear ring $230
#2 Brass 3veins have 3 small hits that caused damage/ Good wear ring $175
#3 Brass perfect veins/ recommended wear ring $230
#4 Brass perfect veins and wear ring/ Needs full bearing rebuild and cone $150
#5 Plastic One small vein hit/ Good wear ring $175
#6 Plastic One vein have a quarter size piece broke off/ Needs wear ring $150
140mm pumps:
#1 Perfect bolt in ready $200
#2 Perfect veins / recommended wear ring $160
#3 Perfect veins / recommended wear ring $160
#4 Perfect veins / Needs wear ring $100
#5 Good veins Alum/brass old school / needs wear ring $75
#6 Good Veins Alum/Brass old school / recommended wear ring $85
#7 Good veins Alum/Alum old school / needs wear ring $75
#8 Good veins Alum/brass old school w/new style plastic cone / needs wear ring $85
#9 Few nicks in veins Alum/Alum old school / Need wear ring $75
140mm Big hub pump:
#1 Perfect veins/perfect wear ring/Perfect prop (Bolt in ready)$425 :hurray::hurray:
Will be adding to list in time so look forward in blog for updates and added on pumps!!
Big hub pictures:
155mm pump pictures with numbers:
#1
#2
#3
#4
#5
#6
140mm pump pictures With numbers:
#1
#2
#3
#4
#5
#6
#7
#8
#9
155mm pumps:
140mm pumps:
140mm Big hub pump:
Big hub pictures:
#1
#2
#3
#4
#5
#6
#1
#2
#3
#4
#5
#6
#7
#8
#9
