gladiator
Dear Dr.honda I need your help. First thanks for this great info here.
I have a seadoo Islandia just got it with mercury m2 jet drive 240hp. I took it on shore and was running just fine until we were tubing and the robe stuck in that grill and around the jet drive. Engine died. So I dived and cut it loose ...I fired up the engine and it started just fine we started driving back once I reach 7 mile the engine shuts off so I had to drive the boat at 5-7 mile per hour for 2 hours straight to get back. The problem was it was very slow and every few min it will shuts off as well as soon as I speed up. But it will start right back. So once we reach the dock I put it on the trailer then cut the rest of the rope from the inside behind the grill from under the boat. Put the boat back on water it went up to 10-15 miles but the again same problem shuts off. But it will fire right back but it will not pass speed of 15. And as soon as I rev it above 4000rpm it will shut off. But if I idle at low rpm and low speed/rpm it will go for much longer like 10 m in vs. 2 min at15 mph. so I assumed that the engine shutting off becoz it is not getting water to be cooled as it suppose to due to the fact it is blocked by the rope that was sucked in. so I assumed there is a sensor that shutting the engine off due to the cooling water system is not circulating and that happens only when I speed. So I disassembled the back of the jet pump drive. I took the rear steering black half circle metal part and the piece behind it as well. Now I can see the everything and the 4 small tube that sucks the water into the engine are clean. No robe or any dirt.
I noticed the impeller had a lot of necks and scratches and the housing as well. But the rope did not coz that for sure. The boat was running at full speed before this accident at 40 mph so it can’t be the impeller and the wear ring (at least I don’t think so). I checked the water hoses from the other side I mean inside the engine. So I took the clams out and the hoses seems clean.
Some fuse were blown I replaced them.
The engine fires up fine with water from the hose. Sounds and runs fine. But does not pass 4000rpm/15mph
What should I do?
What should I do?
