Seadoo GTX Wake
ste1171
Hey Everyone,
I am new to this forum and new to personal watercrafts.
I am looking at buying a used machine. Found one, a 2006 Seadoo GTX Wake edition.
Anything I should be looking for?
I know some of the basic....check for scratches on the hull, inspect impeller and check the compression.
The machine I am interested mentioned above may be from the US. Should there be anything specific I should ask?
Does it matter if it was operated in salt water? (i do not know if it has)
Any other info would be appreciated.
Thanks
Figure out if it is the 155 hp (naturally aspirated) or 215 (supercharged) model.
It's closed loop but I would still see if it was operated in salt water and/or if they flushed it. If you know to check the compression and such then you should be good.
