After months of trouble shooting, I finally figure out what was wrong with my jet ski. I would run for a while just fine and then not be able to go over 2,000-3,000 RPM.
I replaced the:
1) TPS and reset with my CandooPro software.
2) Replaced the aftermarket Rectifier/Regulator with a genuine Seadoo part. ($165)
3) Cleaned all the water cooling lines out.
4) Cleaned RAVE valves.
5) Cleaned Injectors.
6) Replaced fuel pump and filters (59psi).
Turned out to be the Stator. Stator static test showed good specification results (.1Ω to 1Ω). Dynamic test didn't do so good. At the 3 yellow wires coming out of the stator, 1 -2 measured (20VAC @idle), 1-3 (2VAC @idle), 2-3 (2VAC @idle). Specifications call for 25 to 70 VAC @3500 RPM. Bad stator. I replaced the stator with an aftermarket JetUnit stator from Amazon even though I had read that you need to go back to the original Seadoo OEM stator.
Ran great for 4-5 hours total time that I had taken it out at different times. The last time I took it out, it died and wouldn't start. Long story short the MAG side cylinder piston bottom ring broke (85 psi compression). I rebuilt the top end with fresh honed jugs, new pistons, new rings.
Went out to test and break it 787 motor in. Ran for about 20 minutes perfect. After that it wouldn't run worth a s##t. Idled badly, couldn't get RPMs up, stalled, and hard starting. Took it to the house and rechecked compression. 125 psi on the MAG side, 130 psi PTO side since it hasn't been broke in yet. Thought I'd check out the Stator again last night. 1 -2 measured (11.5VAC @idle), 1-3 (11.5VAC @idle), 2-3 (11.5VAC @idle). Specifications call for 25 to 70 VAC @3500 RPM. I tested wiring at 3500 RPM and got worse.....1 -2 measured (8.5VAC @idle), 1-3 (8.5VAC @idle), 2-3 (8.5VAC @idle). The higher the RPM the worse the AC voltage got.
Am I over looking something after the Top End rebuild, or is this one of those Chinese stators that coincidentally went bad?
I replaced the:
