nitrosport_5
I am running dual BNi 38 carbs on my setup. It is extremely hard to start. I give it a couple shots with the primer, and hit the key and it will instantly fire once, and then i have to keep cranking and cranking and then it will finally spit and continue to spit more and more until it is finally almost to running, and then i have to give it another shot of the primer to keep it running. Once it is running, it will not idle. If i turn my idle screw up it will want to stick around 3k rpm and not want to come back down. All of this starting is done while holding the throttle open between 1/4 and 1/2 throttle.
When i am running it, there is a slight bog when i first hit the throttle, but once i get passed about 3k rpm it runs awesome. after it is warmed up, it will still not idle, and still not want to start at all.
All of this is being done on my 1989 Honda Pilot with a 98 670 rotax skidoo engine, with seadoo intake and BNi carbs. I am currently jetted 140 high, with 0 turns out on the high needle, and 65 low end jets, with 2 turns out on the low screws. i have my popoff pressure at 17psi, lowered from 25 and it did not seem to make any difference at all.
Can anybody here help me with some troubleshooting> been playing with the carbs on this thing for over a month and i have gotten a little progress in getting it to run better, but the starting issue is still the same as it has been, from when it was jetted extremely rich, to when i had it jetted a bit lean.
thanks in advance.
thanks in advance.
