fogging
I always fog while at high idle, about a third of a can of Seadoo lube, then shut off water, rev a couple times to dump any excess water and shut off engine. I then pull the plugs, spray oil in cylinders and bump over a couple revs and replace plugs. Never had hull flooded and it stays almost dry in the pumps sumps. I have been a Seadoo owner since 1997 and use mostly in the Gulf of Mexico. Now that I know it is the engine I need to get some estimates or just replace the engine myself, again. Any suggestions where to get an engine and the cost to have repaired/replaced at a Seadoo dealer?
I sure want to find the root of the problem so i can avoid anything in the future.
