Hello all let me start by saying this is my first post here. I have done a lot of reading and correcting problems with other members suggestions. I currently seem to have a weak cylinder on the right side engine it seams to be running richer than the front cylinder ( judging by plug color ) and the engine seams sluggish.. Just got done with a compression test 130 PSI on both cylinders. So I started to trim the plug wires and noticed the resistor cap only on that cylinder was rusted and corroded so I thought I would just replace all 4. The problem I am having now is that the only caps I can find are TB05EM A and mine are TB10EM A. From what I understand the 05 and 10 in that number is the resistance value.. Can I use the lower resistance caps??? By the way this is a single carb. engine and it has been rebuild.
Thanks
Paul
Thanks
Paul
