Hi guys,
I just picked up my new seadoo challenger jetboat it is a project with seized engine and hopefully have payed accordingly.
I got her back tuesday night and got to work yesterday, after realising it is fully seized pulled the engine to find 1 cylinder seized, but the crank also. It has been sat fir a year and i imagine must of taken on some water via the exhaust on its last use (perhaps a sink)
Either way it doesnt really matter how it happened it has, so now i need to rebuild her. The cylinders will hone hopefully, and pistons can be re-used as are in excellent condition considering. Biggest issue is the crank shaft, the big end have corroded and such have pitted the crank, it is relatively light pitting but pitting non the less.
Being new to these engines i wasnt sure on best way forwards, buying a new oem crank will write the engine off.
So i wondered.... Can you grind these cranks? If not has anyone another solution?
Does anyone have a used crank for sale?
Or i have been offered a 2.5 crank out of an outboard but they have only 8 spline for the drive, has anyone ever swapped the end web over?
Anyone got any top tips on these engines? Anything to do/not do with them?
And regards pre-mix conversion is it something most recommend?
Thanks in advance guys
