Hoping someone can help. So Ive been all over this engine lately trying to figure out why it wouldn't start, Found bad trigger wires coming from trigger assembly and replaced it. The moment I tried to start it, it fired right up. Think I probably cranked it 4 or five times in a couple hours time, all good. Well, a few hours later I came out and tried to crank it and wouldn't crank. So I started checking everything, I've got good spark on all cdm's, fuel pressure is good, def getting fuel because its leaking down from EFI module on front of engine. So of course I start looking there. So I pull the ECU and the fuel injection on the front of the motor and leave it all connected. Had my wife turn the key on to let fuel pump turn on and bam... I see injector 1 and 2 spraying wide open flooding the crap out of the engine, they will spray as long as I let them if I leave the key on. So I told her to try to crank it and all 6 spray what appears as wide open also. So I take fuel injection off motor and swap injectors 1 and 2 with 3 and 4. Install back on motor and watched it again and this time, as soon as she turned the key on, injector 1 and 2 would just shoot a small squirt of fuel in and stop, that seemed normal to me, thinking it was like a prime or choke for a start. I believe this proved the injectors to be ok. So I installed everything back and of course the boat fired right up several times. Well here it is a few days later and wont start and if I keep trying then I get fuel leaking again down the EFI module. So I pull it back off and sure as shit, injectors 1 and 2 are firing full force and don't stop until you turn the key off. The first thing im trying to find out is, Is there any reason to think that the ECU would be telling those injectors to fire like that when the key is just in the on position, not cranking? I know they are gonna fire when cranking, but when cranking, all 6 are gonna fire. Im worried I have a bad ECU and its telling 1 and 2 to fire to start the motor and its not shutting them off after a second or so. I know the injectors fire in pairs and the ECU controls them, but im just wondering if there is possibly a sensor making 1 and 2 only fire when key is set to on. , seems unlikely to me but again, I think im just hoping it could be something other than the ECU. Its weird that it worked a few times and now it is doing the same thing. Ive been told about the injector drivers in the ECU burning up or going out, but I need to know what to do now. I have to figure out how to permenantly fix injector 1 and 2 to stop them from flooding my engine. Im wondering if a Mercury dealer can plug into ECU and see this problem or if im gonna have to send it out for repair. Ive got the little 2 wire plug hanging out of the ECU I think its for a dealer test and diagnostic port. Any help is appreciated, thanks in advance.
