Seadoo Challenger 1997 Steering Trouble
philipl
Hello Guys,
I have a trouble with the "steering" on my challenger.
The venturi alignment is perfect but my boat always try to turn on left side at 20mph & more.
I need to turn the steering on left side to be able to run strait forward.
Did you have idea why.
Thanks phil!
I have the same problem. And she lists too. I don't know if the two are related. I was thinking of adjusting the nossle to compensate but haven't got around to it. I am worried to will fix it at one speed and make it worse at all the rest
When you grab the venturi and move it side to side dose the steering wheel move with it? Lock to lock look right?
SeaDoo jet boats have a tendency to go left due to the impeller turning left. Might factor that in you troubleshooting.
Did you get a chance to turn the nozzle when someone is holding the wheel straight? Might be a cable collapse.
Not yet, my boat stay at my chalet and i didn't go back before next week.
Its the reason why i try to find some solution idea.
May be i will order i order cable change it to see if its help.
Thanks'
I try to hold the nozzle during truning the wheel... i feel no slack...
Everything move like its suppose to ....
The only other thing I can think of is pump damage or miss alignment. I would pull the pump and check for impeller and stator damage. Check that the four mounting studs and ride shoe are in good shape.
