Seadoo challenger 1996 quick questions
Lucifert
Hi group,
2 short and quick questions.
1st: are we suppose at all time to get a plug stopper on the second drain hole as you can see pn the picture 1, while running the boat? (As seen on section 5 schema sub part 02) ?
2nd: what is the p/n of the boat drain plug inside the boat as in picture 2
Many thanks, enjoy your day
On a ski, that would be the flush connection and it does NOT get a plug. It is always left open as the exhaust drains from there. I "assume" this is the same for the boats.
Someone else will confirm this though...
As you can see the left obe is the main one and that challanger model got a second one on the right and as i say on the schema it say that the second one need a plug, just need to confirm
One of those is for the cooling system and the other is where the bilge pump drain is. Neither need a plug. As far as a plug for the hole by your feet. That hole does not get a plug it is where your floor drains through the stern. There is a valve on the back of the boat that should allow water out and not to come back in. If water is coming in you either need to clean the valve or replace it. It is called a schulper valve. Hope I spelled it right.
