Renny Lagares
Hey i have a 97 seadoo challenger 1800... I just put 2 sbt 82.25mm engines in and my pockets are getting thin... I have a fuel issue... I have replaced everything in all 4 carbs w/ mikuni kits and new 67.5 l/s jets and 140 h/s mag and 145 h/s pto jets... It has new springs and levers... Also new needle and seats in all 4 carbs.... Pop off pressure in both mags are 35 and both ptos are 32...
All fuel circuits are clean and ive pressurized the l/s hole and im getting a solid 31psi in both the l/s needle circuits... Ive replaced all the o-rings on the needles...
Rotary plate is set on timing... 150psi all 4 cylinders... No vacuum leaks....
Clean gas tank - 40 gal of 90oct ethenol free gas w/ 32:1 mix... Breakin process
NEW FUEL LINES, FUEL FILTERS AND HOSE CLAMPS
my problem is the boat doesn't want to stay running... Throttle response is horrible (bogs down when throttle up then revs but weakly) not like a 2stroke should respond... I can get it started on land idle 3k rpm throttle response quick... But when i have it in water i can't get them started easy...
I choke it and itll fire up idle for a sec shut down and then its hell to start either one...
I am getting fuel to all 4 carbs... 4 new spark plugs (br8es)
l/s needle 1.5 turn out h/s needle close
stock flame arrestors
plugs aren't getting wet but they are not dry either...
If i spray mix gas w/ a spray bottle into the carbs it start idle smooth until it burns out...
Ive bought everything that i could think off that is replaceable in these carbs and im not getting any results.... I even paid one of the worst jetski mechanics on the face of the earth 300 to check replace rebuild whatever my carbs and all i got was oddball pop off pressures and no starting engines...
I have better results doing it myself...
I am trying to find a solution or maybe somebody on the site that has a repair shop that will be kind to my pockets and i can send the carbs to so they can check and fix, so i can just recieve them back and bolt them in and start riding
as i said in the beginning of the post... These are 2 82.25mm bore engines... I shouldn't have to up the jet sizes or anythihg....
