Looking for someone that might be able to explain.......
I took my 2000 Gtx out last weekend, it was running perfectly, then all of a sudden in deep water i did a little turn and went to accelerate again and the seadoo wouldnt go anywhere. like as if when the intake is plugged with weeds, the enginge would rev up and i could tell the impeller was turning, sounded exactly like when there is an obstruction, but there wasnt. I pulled it out of the water made sure there was nothing in the intake as well as checked out the impeller, everything was fine, no dings on the impeller at all? so i put it back into the water, still ran the same. But i soon found out that if i sat there and let if rev for about 20 secs, all of a sudden something would kick in and it would take off and speed right up (but still not to top speed like earlier in the day). this does not make sense to me? its direct driven by the shaft, could the impeller be slipping on the shaft?
