Hi,
I now have a 1998 GTX Limited and have just passed the 100 hour-mark and the ski is just fantastic.
I got some useful info about alternative 2-stroke oils on the forum, but unfortunately I could not find the brands listed here in Australia. However, for the record, I found another brand that is readily available, and it is called Penrite Hi-Per. Like the other brands mentioned, it specifically states on the information data that it is approved for SeaDoo 2-strokes. I rang the local SeaDoo agent and he agreed it was an identical oil. It is around 1/4 the cost of locally-available SeaDoo oil with identical specifications.Just passing this on in the hope that it helps someone.
On a similar theme, can anyone advise a suitable replacement for the SeaDoo Bombardier engine lube? (also prohibitively expensive here). I understand WD40-type products are not suitable but surely there are quality lubricants that will do the same job? My local mechanic advises 10-seconds of Bombardier lube down the intake on fast idle while flushing. Is this recommended? Can't find any reference in the manual.
How often should the engine be 'fogged' and should this be done with the SeDoo lubricant or can a light engine oil do the same job? Should the lubricant/oil be left to settle for a period before turning the engine over?
Should the engine then be re-started briefly immediately after the plugs are replaced?
I have noticed original SeaDoo DESS lanyards available on the internet for around $US75. Will a SeaDoo dealer still program one of these if it hasn't been bought from them? Are there any known problems going this route? Locally dealers want $300+ for these, plus programming fee
Has anyone had experience retro-fitting the rear spring-step? When fitted as OE, I notice the steps are bolted through the transom. This is pretty much impossible as a retro-fit. So the question is can you get a secure mount with self-tappers or self-sacrifice type screws or do you need an expanding inner retainer-type bolt or some other special fitting. And regardless what type of sealant do you apply to ensure it doesn't leak?
I am also interested in retro-fitting wakeboard mounts to the side rails. Has anyone had experience with these? There is less loading on these than the spring-steps, but I wouldn't want one to damage the hull anyway.
