CreekerMike
Greetings and salutations to all.
I got my factory piped 720 assembled and installed this past weekend. I dont have the necessary carbs yet however so its not 100%. I fired it a few times on starting fluid to show some of my buddies. Sadly I saw oil in the hull (this was after an engine out pressure wash) I know the feed line to the rv can crack and leak. However I knipped the hose back a little to give a clean section to clamp to. After some inspection with a mirror and my cellphone I found this. It appears the oil is leaking from the threads of the feed fitting? Have any of you seen this before? Judging by the fact the oil is half way up the threads I think its safe to say that's the leak. Just seems strange to me. I may add this is an sbt engine. My plan is to pull the rv cover, clamp both lines. Install oil pads/ rags under the engine. Then remove/retape the fitting. Any thoughts or advice is much appreciated.
