hi guys can you tell me what my 720 gs 1999 model compression should be when its cold ,its showing 160 psi or 11 bar is this low ? it wont start in water only if i tilt the ski so the exhaust is out of the water, takes about 10 seconds to start when it cuts out, as soon as the exhaust goes into the water it cuts the engine out but it will run on the drive with the hose pipe no problem, has had full engine rebuild inc pistons and crankshaft but as the barrells looked good and no scores I put standard size pistons back in, may be i should of gone 1 oversize with the pistons or has anybody else had the same problem please help guys
