Paul gts
I've got a 95 657x engine that I had running from a 95 parts ski that got rock damage to the pump and hull. When I was stripping down the engine to install in another 95 gtx I noticed black oil in the exhaust manifold and took the cover plate and rotor off.  I tipped the engine on it's side and recovered 4 ounces total out of both ports( crank case) it has 150 psi on both cylinders and the rotary valve has a slight rust halo on the backside of the rotor , telling me it sat for a while. It looks to me it sat for a while and I think the oil in the crankcase on both sides is telling me the center seals are back and weeping oil.  So, my question is if I try to run it will the seals tighten up or should I not bother and rebuild and is 4 ounces of oil acceptable for a motor that sat a while ?
		 You many not even have a problem at all.  Good Luck !
