Hi, I recently got hold off a 3D that hasn't done many hours but hasn't run in 5 years. New battery, fuel, plugs and general clean up and it's now starting and running well. First ride out on it though the engine cut out due to exhaust gasses leaking from the plastic T fitting on the exhaust.
I'm assuming there is a cooling issue so I'm now working my way around the hoses and valves and checking for blockages.
So far I've been able to blow through everything except the elbow knuckle that is the Anti-rollover bypass.
My question is should this be clear or could this being blocked be my problem?
Any help, advice much appreciated.
