philinkeys
SeaDoo 2001 Islandia Starting Problems: Desperate for HELP. ANYONE. I do my own maintenance up to my limitations. Problem: When I engage the starter the starter motor rotates a few seconds and the starter bendix disengages. I changed the starter and the solenoid but that did not resolve the problem. Someone mentioned it could be a fuel problem causing the starter to cut out so I changed the fuel filter and the fuel/water filter. I also changed the electric fuel pump because the old electric fuel pump would run about a minute before shutting off. The new pump now turns off in about 35 seconds after turning the ignition on. I also changed the pulse fuel pump and the electric fuel pump in the vapor chamber which did not help either. Even if I bypass the ignition switch and jump the solenoid the starter still disengaged in a few seconds. I need subjections I’ve reached my limitation. philinkeys
