Sea-Doo Virgin!
CampCobb
I am looking into buying a 2005 Sea-Doo Sportster 15' 215hp. I have not looked at it in person yet but pics seem good so far. He says all is in perfect condition (button, electrics, engine and all) down to the manuals and video that came with it. Is there anything I should be aware of and look for when I visit the boat before purchase? Asking price is $9000. I am discussing price as of now via e-mail before I take the time to see it. Thanks for any and all info. CampCobb
Oh yea, full Sea-Doo cover and cd/fm are the only options on it.
Here are my thoughts to you.
I assume this boat has no warranty from BRP. With that said, no way would I buy unless the boat was inspected by a Seadoo dealer. Have the dealer hook it up to buds and get all computer readings.
I've owned three Seadoos over the last five years. The gelcoat is mediocre. Inspect the boat up close and personal and check every square inch. Mine have had many gelcoat cracks that were all repaired under warranty.
You must sea trial it. Make sure the levers(especially the forward/reverse gate) actuate smoothly and without alot of effort. That boat should launch out of the hole. If it cavitates(like a car when the transmission slips) you have impeller/wear ring issues.
Did the supercharger have the ceramic washers replaced? This is a must if not done.
The more particular you are now the less dissappointed you will be a month after your purchase.
Craig
Kinda high...
I think the price is kinda high.
That year model had problems with the exhaust valves. They were hollow, silica sodium filled. They were known for dropping the valve and destroying the engine.
This is also the year that ceramic washers were used on the superchargers. These washers would deteriate and stop up the oil porting inside the engine.
Is it a good buy? To me, no... it's to expensive for a model which is known to have problems. For a few thousand more, you could get a new one with a 5 year warranty. I would love to support you on finding a nice seadoo. But, I've hear way to many horror stories on this year motor....
I'm sure you'll probably here more about this model 4-TEC.
snipe,
When other people bashed the ceramic washers, I remember you saying in other threads that the washers being ceramic is the best material to have as far as heat and wear, what do you think of the newer steel washers as far as that design goes, could it be that most of the charger failures are do to unhooking, I think that if you didn't jump waves like crazy and just drove the boat like normal and did your oil changes you shouldn't have many problems with the charger.
snipe,
Thats the problem right there seadoo mike, with all do respect, who really wants to drive there boat like its a classic car? who doesnt want to jump waves? ( unless your newborn is in the boat, or someone with a broken leg ).it would be much more advisable to just, not get a boat with these problems. no boat shouldnt be able to jump waves, because well, waves exist everywhere
I am going to have to agree with 96seadooxpBC on this, and I am not trying to start a flame war, or bash anyone here, but the model that he is looking at is meant for those things. Jumping waves, cutting turns heavily, all around good times.
I would not recommend the boat you are looking at. The price seems high for the current market. If you want a newer model, you may want to look into the 08's and above, especially if you are looking for a supercharged model. If you go with the 155hp model, you are looking at good speed and acceleration(not as much as a supercharged model) and less maintenance. The superchargers need to be rebuilt around every 100 hours. I looked in your area, and noticed a dealership with an 09, don’t know which version it was, but there are a few more, some that didn’t list what they had available. I would make some calls before buying. One other thing to look at if you are going used, get the hours on the motor, as well as a maintenance log if available.
I wish you the best of luck, and happy hunting :D
Catch "22"
snipe,
This is actually a catch 22 kind of issue. If I were the one with the supercharged 4 tec, I'd prefer to have the ceramic washers, just for the reasons I stated. Ceramic is one of the only known materials that does not retain heat. It can also provide a durable, smooth surface for rotating equipment.
If you google ceramics uses in the mechanical applications, you'll see even NASA uses it.
Here lies the problem. Seadoo's have forever used a synthetic/blend of oils in their watercraft. When you see the oil designation XP-S, a lot of people think the "S" means synthetic. These supercharged engines were the first to come out using the standard mineral based oils in a long time. And I think the Seadoo research and development department didn't take into consideration that there might just be some owner, along the way, change over to the synthetic oils. Synthetics don't burn and are way to slippery for the slip washers.
I still maintain that the ceramic clutch slip washers are the best choice for this application but, when coming in contact with synthetic oil, the properties of the oil cause the washers to disentegrate and can find their way into your internal porting of the oil system. Just replacing the washers after this happens, does not protect you from further engine damage if you can't account for all the pieces of the washers.
Seadoo went to the stainless to because of liability, not because it's a better product. The stainless gets hot and retains heat. But, the oils (now the newer brand of synthetics can be used) maitain it from overheating.
The motor coming un-hooked from the water has nothing to do with this issue. What your looking at here is damage. The supercharger operates in excess of 40,000 rpm. The engine, around 8,000 rpm. When your riding wide open and you take air, the engine and charger speeds up. When you land and re-connect to the water, its like puttin the brakes on the charger. Yes, the slip washers will take up some of the slack but constantly doing this will damage the charger and/or motor. Because the charger is geared to the motor, it will want to speed up and slow down with the motors RPM. Well, in reality, that's just not possible with this component part. So, the slip washers take up that slack. But if you look at the motor doing a standard increase or decrease in speed while riding, that's significantly different than the motor coming un-hooked and then, re-torquing when it lands.
That's the double edge sword. The catch 22 on these chargers. Honestly, I don't think the application of these things are even feasible for the watercraft.
If you think about it, manafacturers are always going to add something, change something, create more horsepower or ways of achieving higher speeds with each passing year. Why? Because no one wants to buy/see the same old thing every year. And manafacturers know that change sells.
Look at the 951cc 2 stroke. That motor is almost as fast as the expensive 4-TEC. Just won't reach the speeds as fast. But, over the last 10 years, they've had to increase the horsepower just to say they have something new to offer the spending habits of the public. Look at the 4-TEC. That motor hasn't really changed design in almost 10 years, but it's changed horsepower and the addition of the SC and SCIC ......
That's how I see it. I'm sure, many others see it a lot differently.
A little real world experience
Bought a brand shiny new 08 215hp Sportster. Followed the break-in to the letter. Took it to the dealer at 10 hours for the first service. At 11 hours the blower washers let go. Seadoo was very apologetic and replaced the blower. Got the boat back, ran her about 1/2 hour and the oil pressure alarm went off, and the computer shut off the engine. Fortunately I had joined Boat U.S. and got towed back to the Marina. Dealer swore he had flushed the engine, guess he missed some stuff. After much threatening about Arizona Lemon Law, Seadoo gave me an extended warranty, and their B.E.S.T. service agreement. (something like that) I am now covered for 5 years, and they pay for all routine maintenance. Don't get me wrong, I love the little Sport, it fills it's purpose nicely and it is fast as hell.....
Good Luck, happy hunting!
snipe, I hear what you are saying, and don't disagree, I just think alot of people are scared with the SC models, yes--a little more maintenance, but if you do most of it yourself its not really that bad.
as for our wave jumping friends, with all do respect, not everyone out there looking to buy a boat is thinking about jumping waves, I don't think your really getting a pontoon boat up in the air or want to for that matter. The reason I went with the SC model is because I wanted better WOT plane and simple, even looking at the at the 15' sportster you can't tell me that the 155hp version would have near the same WOT as the 215hp or 255hp models.
i did over 200 hres on 2005 speedster 100 whit new metal washer external intercooler riva sc wheel gibson exhaust and a lot more stuff never ad any trouble except for a alternator wire that melt it was a easy fix. the boat was fast fun and i will mis it .and i thrust the sc motor i bought a 230 wake 510hp.so deal the price check how many hours put the sc washer good oil and have fun.
These SC/NonSC arguments are really starting to get old.
I drive a sports car, and with this comes the added cost of tires, clutches, synthetic oil, etc.....if you aren't willing to incur these extra costs buy a Honda civic. Are you going to have the same amount of fun? Maybe, Maybe Not. The same goes for the SC/NonSC boats, is the NonSC boat going to be fun? Yes. As much fun as a SC boat? Maybe, Maybe Not. Depends on what you are looking for. If the 100 hours rebuild of the SC is the deal breaker you probably should look for a cheaper hobby. It's really no different that replacing the clutch on your car.
You have to pay to play, no way around it.
Maybe a bald guy like me who enjoys the cruise to Canada, fishing shallow places and the occasional desire for speed with family tubing, this is why I chose a 5 pass with water flexing exhaust 780 engine - still have the 3 seater 95 gtx but it hurts when I fall asleep and land in the water.
Nothing is old.....
Real quick to Cypher.... nothing here gets old... Why do I say that. Since 2007, I bet I have answered the same questions on certain topics a million times. So, I can honestly say, they never get old....
As for the quote.... If I was offered a good price on a SC or SCIC 4-TEC, I might take it. Sometimes I'm on the fence with it cause of the maintenance. But, ... Someone like me could buy and handle the supercharged version of this motor with ease. I'd do my own maintenance (I have a problem trusting shops) and when necessary, rebuild the charger myself.
In the other opinion I made, about getting the N/A model; that's really aimed at "gas it up and ride" kinda people. You sound like, along with some of the others, that you know what your talking about. Well, in what I'm trying to point out is, a lot of people don't know what the supercharger even is. There was a member in the forum a couple weeks ago that called it a turbo charger. So, if you get someone looking to buy a boat and has no idea what it is, how it works and what kind of maintenance its going to take, it just seems more feasible that they get a boat equipped with a motor that won't be so technical that they can't understand it.....
What I meant by the boat coming unhooked from the water, wasn't pointed at "wave jumping". I was making reference that if you were WOT out here, where I live, you'd be catching air and if you didn't let off the throttle, engine would speed up and create a hard grab on the clutch washers. The bay (Mobile Bay) or out near the Island is or can be, pretty choppy.
Like you said, I don't make it a habit of taking my Challenger out and trying to jump waves with it, its for my daughters to tube behind. But, when I've been out, crossing the bay heading to Fairhope, I have caught some air. So, that in general was what I was referring to.......
There are killer pros and cons on these things. I bet it's a 50/50, or maybe even a higher rating on those that are pro charger. It's all good. But, knowing what you have and what it requires should bear some of the decision on whether to buy a N/A boat or a SC/SCIC boat.........
:cheers:
