mchiappinam
Hey everyone,
A couple days ago I had a problem with my SPX 1994 (657) for not having spark. After replacing the stator and coil it came back to life yay
I put it in the water today to test in NJ (60 degrees ), it worked great. After running full throttle for about 25 seconds, it died. Started again with no issues and gave full throttle again to confirm if it was running lean. It died in 5 seconds. I started again, running half throttle back to the boat ramp. It was running perfect. So then I gave full throttle again after 1m in half throttle and I was able to run for about 25 seconds again till it died. That gave me a confirmation that I have some issue before the carburetor.
After stopping, I cleaned the gas/water separator filter and replaced my ¼ in line gas filter with a larger one (more flow).
After that, I had a hard time trying to start it, until I gave up and put it back on the trailer. When it was in the trailer I started it very easy, but something wasn't right. Removed the spark plugs and the pto one had some stuff welded to it. That scared me.
I drove home and checked the compression, mag piston 105 psi (usual).
Pto piston 60 psi.
I was sad, of course... Removed the top end and confirmed... It was the piston.
Running lean for a short period of time can cause this? Or probably was another problem?
Bad timing with the stator can be the issue?
Is it possible to replace only the pto piston? (Probably not worth if possible, right?)
Thanks and cheers!!
Pto piston 60 psi.
Thanks and cheers!!
