Scubadave16
I have a 2005 Sea Doo sporster with the 3 cylinder 4 tec engine. It has been running fine until just recently when it starts stalling out when i pull the throttle back to idle. it typicaly does this after i have run it a while not usually when pulling away from dock. once it stalls it is somewhat difficult to restart, but after 15-30 seconds it does restart. I maybe? smell a little gas when it restarts but not definite. once it starts up it seems to be OK but then when i pull all the way back on the throttle say to dock it it will stall out again. no hesitation, no knocking, no backfire; just quits.
some info. I keep it in the water all the time. I have in fact pulled a ton of weeds into the intake and have to pull em out several times a day. I put new spark plugs in last spring. the boat has always had an annoying surge at certain RPM which i am led to believe is pretty much standard with this model.
the gas is still the first fill from mid May since I haven't used it very much this year (sadly).
any help would be appreciated.
