R rado New Member Sep 27, 2013 #1 Sea-Doo Speester 240HP 2003 Don `t spark and beep? My Sea-Doo does not say peep when I install the key. The engine will not start because there will be a spark. Where to start searching wrong? Thanks to advice I've Finnish Last edited by a moderator: Jan 3, 2014
Coastiejoe Moderator Moderator Sep 27, 2013 #2 Does the engine turn over? Get a meter on the battery and tell us the voltage when TRYING to crank the engine. Post your findings here. Jump the solenoid with a screwdriver, tells us what happens? Once you give us this info, we will go from there.
L LouDoo Premium Member Premium Member Sep 27, 2013 #3 Hi and welcome to the SeaDoo forum. I believe you have a Mercury power boat, I'll move it to the proper forum, our resident expert Dr Honda should pick up on it. Lou
R rado New Member Sep 27, 2013 #4 Battery voltage 12.8V and the machine runs very well. The engine will not start because there is no spark
Coastiejoe Moderator Moderator Sep 27, 2013 #5 As Lou mentioned. You have the Merc engine. I missed that when I first read your post. The Merc is a different animal compared to most Seadoo engines. Dr Honda will be better suited to help you. Last edited by a moderator: Jan 3, 2014
FastFive New Member Sep 27, 2013 #7 rado said: How to identify whether the boat is 2002 or 2003 ? Click to expand... The Hull Identification Number will tell you what year the boat is. Its located under the swim platform on the starboard side.
FastFive New Member Sep 27, 2013 #8 The last two numbers indicate the model year. Example 02 would be model year 2002.
R rado New Member Sep 27, 2013 #9 Okay. Thus boat 2003. What is better in 2003 than in 2002? Oil wheel of steel?
FastFive New Member Sep 27, 2013 #11 rado said: My Sea-Doo does not say peep when I install the key. The engine will not start because there will be a spark. Click to expand... Is the Lanyard connected?
R rado New Member Jan 3, 2014 #14 Missing from the picture one 20amp (yellow) fuse. http://aijaa.com/krTBbo What's that fuse mean? I put a new fuse, but still does not spark. Where to look for a problem? http://aijaa.com/krTBbo Last edited by a moderator: Jan 3, 2014
