Still chasing a problem on 2007 Speedster 200, with twin 215’s. I’m almost certain this is a DESS problem. It might be 2 separate problems. While idling out, the port engine will die. No beeps, no engine lights,nothing just dies. If I push start button I get nothing, no beeps no starting. So I pull the DESS lanyard, and reinstall it and it usually get 2 beeps per engine and it starts right up. Then it may die again after a few seconds or a few minutes... then I pull DESS and reinstall and it will fire up again. At some point it will remain running for a while but may die again, no Rhyme or reason. Sometimes like yesterday, it dies and I pull DESS and reinstall and the DESS doesn’t respond, so I put DESS on and off a bunch of times and may take 3 tries may take 20 tries and all the sudden the DESS works and i get my 2 beeps for each engine and I fire both of them up and I’m on my way. This almost always happens after boat has sat for 5 hours beached and it’s when I try to start it to go home. Doesn’t make any sense. Most of the time when I put boat in water both engines run great for 20 min solid hauling ass around the lake. But once I park it and let it sit a while something is happening. It always starts up to go home, but port engine is guaranteed to die. Definitely seems like the DESS system is problematic and is shutting down the port engine because if it wasn’t the DESS then it should start right back up without having to pull the DESS. I’ve tested that, by just hitting stop button while both engines are running and it kills the engine, then I push start and it fires right back up, don’t have to pull DESS. BTW, I’ve replaced DESS with OEM DESS post and DESS key from Sea-Doo. I installed voltmeter and new battery, I’ve swapped the ECU’s on engines, I’ve swapped fuel pumps on engines, I’ve installed a brand new VCM twin engine module. The problem has stayed on the port engine. And the DESS is just very inconsistent. Works 100% of the time when in driveway or starting for the 1st time but after that you never know if it’s gonna cause problems. I have a CANDOO pro and no codes except P0600 which I’ve been told is a code almost always there when using a CANDOO, has something to do with the connection of Candoo and the boat. Loss of packets or something. I’d love to hear some ideas of what else to check and troubleshoot, I’m out of ideas.
