Sea doo speedster 1996 engine problems
Karna
Hello,
I have a problem with my engines. The engines run nicely on idle speed, but when I put even a little throttle on the fragmentary running start´s. I think it´s a rpm limiter problem or something else, like temperature sensor problem, that gives signal to the egnision not to light up. I know that in neutral the rpm is limited to 3500rpm/min, but at the time the engines give out only 1000rpm/min maximum. What could be the cause? How can I solve this problems or at least find out little bit more. The gas flowing is OK.
Peace UP
Joni :facepalm:
It sounds like you are having a fuel feed issue. If there is an air leak in the fuel feed hoses... you will draw air.
But... I would also remove the carburetors, and clean them.
