Hey everyone is 120 psi in each cylinder normal for this ski ? It’s a 2001 sea doo rx it seems to run just fine in the water hitting 59-60mph and rpms are at 7100 could my compression tester be bad ? Thanks for any advice !
I've read that under 120 and you are looking at an upcoming rebuild, 120-130 OK and 135 newly built. There is also chance your tester is showing on low side and should be verified, but aslong as it runs good I dunno?
I called SES about 120psi compression on a Carb 951 and Tom said that's about the half life. I ended up doing a top end. Easy enough. I like to abate the impending disaster when possible. LOL Doing a top end is prevention to me.
