alsen
I have a seadoo 1998 Seadoo Challenger 1800 and I've had it out on the water a few times this year. I have several issues with the boat and need direction as follows: i. On the port engine if I apply full throttle to both engines the RPM consistently increase (and the boat accellerates) till about 4500 RPM at which point the RPM on the port engine jumps to over 7000 RPM almost instantly and makes a high pitch spinning sound almost like its spinning in air. I also loose thrust at that time. Is this what cavitation is? If not what does this issue sound like? Furhtermore - if instead of applying full throttle I do the same thing but gradually as the speed of the boat increases I can get the RPM to almost 5500 before the same problem occurs. ii. Can the issue noted above be caused by an imbalance in power output? iii. On this particular model is there a seal between the jet pump and the hull? I can not find one on the parts diagram for this boat and i've confirmed in my boat there is infact no seal but that seems odd to me. iv. What test should I undertake to narrow down as to what the problem is? Either on-land tests/inspections or in-water tests to determine where this issue is originating.
