Sea doo challenger 180 2010 255HP
hi, The check engine is open and the motor do not try to start when i press the start button.
A repetitive sound a beep is listning.
Do you know where is the plug for scan the check engine code with a scanner ?
thank you
Need help fast as you can if you have some question let me know
You cannot use a regular "car scanner" for Seadoo's. You need to either go to the dealer or buy a Candoo Pro. I think it costs around $400.
Could be a bad neutral switch? Try wiggling the shift lever slightly from F and R to N see if starter won't engage.
Could also be a bad start/stop switch. Just had that problem about a month ago. Replaced the switch and all was fine.
I haven't experienced that problem, but when I had a cavitation problem (sucked in a rope) and the exhaust system overheated, besides a text message describing the problem, the trouble code displayed on the instrument panel. Try it again and watch the panel closely - it may display the code. Mine is a 2009 180SE, I expect yours should be the same or better.
