I did not see that racerxxx but good idea , I marked the pto tdc on hole one and hole two they seem to be right on 180 degrees of each other , the book said it may need to be programed if you remove the stator or trigger I did both you think that will take care of the missing ? can it be out of time that much from that ! it was also missing a corner off the rave valve idk if that happened when it backfired or way before and was woundering if that could of got stuck back in the exhaust . I had the front two exhaust pisses off and didn't see any of it ?
