JAYSONFLYNN
1996 GTI with 717 won't idle consistently and is hard to start. Runs great after startup at anything above idle, but when coming back to idle acts like it's loading up, have to feather throttle to keep running. Can pull the choke halfway and it tries to die. Adjusting low mixture screws and its noticeable when gets lean or rich, runs even worse. Premixing at approx 45:1.
Motor has 20 hours after complete rebuild, 140 on both cylinders. SBT machined rotary valve cover and rotary valve. New fuel lines, deleted fuel selector valve and routed to reserve on the pickup. Removed original water separator and added inline filter. Lots of new plugs and now running iridium NGK's.
Thought it was a carb issue, bought another set and had them professionally rebuilt, but no change. It's charging at 13.7 (have an auxiliary gauge mounted).
Check valves are probably original, about the only thing I've not changed, although did loosen fuel cap to see if vapor locking, not change. Removed seat to make sure not taking in exhaust, no change.
Any advice or ideals appreciated.
