I want to hear your opinions on power, reliability, etc. I have read they are a little underpowered.
Any opinions on price? The 3d I looked at started right up and looked clean, and of course I would get it checked out by a local machanic.
Thanks
I bought a new 2005 3D base model in late 2007 and am happy with it. Bought it mostly as a first-ever PWC to ride the grandkids around and see if i want to get a bigger one. Gave $2500 + tax (but sold with no warranty) then and had to drive 300 miles to Huntsville to pick up. I did have a problem that turned out to be faulty spark plugs, but ran fine after i finally replaced the new-looking plugs with some fresh ones.
As-purchased it had NO seat at all. I found a new Kart seat kit on ebay and am still looking for the bananna-type seat and a reasonable-priced Shoq pole. The seats are not cheap either and i have never seen the bannana seat KIT on ebay.
If you are athletic/young type you will be able to use it in standup mode. Im just an old big fart so i havent tried standup yet. Its a fun vehicle and the base model goes fast enough for me. Clocked it with GPS at over 60mph straight line and i weigh 265 or so (beyond the spec weight for the thing).
It is stable at any nonzero speed and unstable when sitting still. I havent found a graceful way to get off of it yet. I have dumped myself in the lake a couple of times and been able to reboard in deep water but its tricky. Especially when you have to get on, then your 5 yr old grandson has to get on too!
If i had any complaints, they are minor. The engine cover comes completely off (not fixed hinge) and its kind of unwieldly. There is no storage to speak of - just a little tray - and you have to open the engine cover an keep it from falling off in front. Tricky if you are out on the water and need your cell or something. Also, the winterizing procedure to get anti-freeze in cooling system sucks. I couldnt get the fluid to go in after removing and pinching hoses in the instructions. Had to rig up a gravity feed and wait forever for it to go in. Bombardier says use premium gas and i do. Also, the recommended injection oil is expensive. But it doesnt seem to use very much injection oil at all.
Im a do-it yourselfer so what i REALLY DONT like is that a Bombardier proprietary code scanner is required to pull service codes and running hours.- But their build quality is great. If i dont have problems, good.
Overall, its a fun little toy and i would like to get a new GTX or RXT to go with it.
