sea doo 1990 gt impeller
KNAGLE
Hello all. I have a 1990 sea doo gt. The hose was placed too far into the intake port during flushing. The hose wrapped around the shaft. At the first sound of trouble the engine was shut down. The hose was later freed with plyers. The hose had a cut in it from where it extended to the impeller. The impeller would always vibrate a little at low idle. After the incident the vibration sound was louder - at home. Later, the jetski was put back into the water and run for 5 minutes. No problem until a second person got on and we taxied out to the ocean. Halfway there, a higher rmp sound was made. Then, there was also no propulsion. We have it home now and have loosened and retightened the pump housing. It sounds and runs fine now - at home, but is not under water pressure. Thanks for replying..... Kevin
Wearing ring.......
It's your wearing ring. On the top of this page, you'll see a tool bar. Please use keywords like.......wearing ring.....
You should find a lot of info on this part.:cheers:
