Seadoopilot
Is there even a good place for a sacrificial anode on one or two on one of these boats ?
Yes Timmy...and remember don't lick the mints in the urinals.
So My 96 did come with them and they were on the ride plate
I have been sailing for many years and know their use well . Know they are wired together in a sail boat so when you have many seperate metal componants in a boat , A heavy grounding wire is wired from one componant to another ,(IE engine block to bildge pump to chain plates to keel pivoit etc.) this keeps the metal parts (Cathode) wired to the Anode .
To increse the surface area sime anodes look loke computer heatsinks
And note to the un informed NEVER PAINT THE ANODE , keep it nice and shiny.
I had:banghead: a friend named David that hated the anodes on his boat corroading so he kept them painted :banghead::svengo:
If your 4tec engines use a standard coolant fill cap , a drop in anode is available
The sacrificial anode on the boats if located under the jet pump, on the ride plate. But, it's a joke.
Anodes are made from zinc and used to slow the electroylsis process by attracting and grounding the electrical current. Over time, they erode and have to be replaced. Mine has one and for the time I've had the thing, I haven't seen 1mm of loss from electroylsis................you can buy bigger ones and put on it. If you do, they need to be on the ride plate. That's the only metal surface on the boat..........:cheers:
