Hello,
first of all, I will introduce myself. My name is Edgard and I'm from Spain, hence sorry for my english but it isn't so good. I have read you since 3 years ago and I solved a lot of problems of my old pwc (gsx limited) thanks your. Now I have a new PWC (RXT 2005) that when I bougth it, I know that doesn't run properly. Old owner told me that the oil mix with water.
When I arrived at home with the new PWC, I checked the oil and it was too milky. Also, I checked the exhaust valves references and it was the bad reference (72XXXX....). So I decided remove the engine and rebuild all.
I check the oil cooler and it was a leak. But I don't know if is possible that the oil was too milky by the oil cooler or it could be another leak from oil/water. Also, I think that old owner turn over and he doesn't flush oil properly.
This is part of oil that I removed from the engine
What do you think about this? Is possible that this milky oil come from the water mixed on the oil cooler? As a comment, when I removed the oil cooler there was a clean oil on the side of water (transparent oil, no milky). I will replace the oil cooler and put a new head gasket, but do you think that there are another gasket/seal that can mix water in the oil? Oil pump seal for example?
I will inform you if I find something new.
I attach more photos.
Regards!
Regards!
