Douglas J. Dolvin
RXT 215 Colleagues;
correction to the title: I own an 2010 RXT. I am experiencing rattle and low power in mid range 2400-400 rpm. from what i have read on this forum to date; sounds like I may have a drive shaft weart problem; very typical for 2010 bikes; many recommend replace with 2011 like kit.
Symptoms: I took it out yesterday for the first time this year; ran like a jewel, on flat water, accelled from idle through steady operation for a cruise of approx 20 plus miles at constant rpm (4800) and 30 mph. Then I eased off on the throttle when approaching the marina and felt a clunk under rear seat; felt like a hard transmission downshift; lost power at moderate RPM; but idled very level and solid at approx 1720 rpm and 3 mph; so I proceeded to the dock. no error lights/indicators on dash board; so I checked oil levels and engine bay for damage; checked drive from underneath for damage but found nothing. I started the RXT and headed for home. Again, idled well; so i slowly accelled up to 2400 rpm and then engine started to garble and something rattled a bit (again it sounded again like it came from aft of motor). Delivered poor/insufficient power. This continued until i got up to approx 4200 rpm; then it settled in to a solid and quiet operation; ran very well up to 4800-500 rpm (this is as high as I pushed it). It ran well for the entire 5 mile cruise home, until I slowed again below about 3800 rpm; experienced same symptoms down to 2400 rpm. I changed plugs this morning and conducted test operation; same results. Bottom line is it runs well above 400 rpm; rattles between 2400 and 3800.
Regarding fuel and/or fuel injectors: it was winterized by a local marine repair center (not a Sea-Doo dealer). I assume that they used fuel stabilizer; but either way, i topped it off with 10 plus gallons of fuel (89 octane) before setting it in the water yesterday; so likely not much fuel in it during winterization.
Any insights?
Doug at Norris Lake
Any insights?
Doug at Norris Lake
