Rxp215 oil capacity
About 3 quarts- have 4 on hand. Don't over fill or go past 7/8 to full area within the dipstick marks.
2004 RXP, 2006 RXT, 215 Supercharged
Look at the manual on how to check the oil properly, alot of guys do not do it correct. Some engines you have to run it for a minute and then wait a minute before you check the oil level.
If you follow the procedure in the manual when removing the old oil, you will get use 1 gallon to replace it. This will bring it up to the mid-range on the dipstick. That's why the oil change kit comes with a gallon of oil.
Chester
