Back Water VS Open Water ....
:coolgleam:RXP-X vs. RXT-X aS.
It's night and day. As wiser men above have noted, the two-seat RXP-X is the machine for carving and lightweight out of hole performance. The weight difference between the two craft is a little over a hundred pounds. While one is listed at 255 and the other at 260 they have essentially the same power train. The larger RXT-X is heavier and when you go with the active suspension option the weight difference is a bit more. If you're riding open water in 3-5 footers, the larger active suspension is the way to go. If you're riding back water with minimal chop, carving turns, the shorter boat is the one to have.
I own both a '08 and a '10 RXT-X. The '08 is the three seat version of your boat. The extra's on the newer model are cool. I like the fly-by wire system, and having a break. Relocation of the battery and a hinged seat are not that big of deal. The handle bars allow more adjustability. The newer hull handles the chop a little better and the gloss black looks great both on the trailer or in the water. Are there any drawbacks to the newer design. Yes, there are a couple. Storage is water tight but its small, second speed is governed by gps on the new models.
