rxp help
carteman
hi i have a seadoo rxp i am looking to do the washers in the supercharger while taking the seat cover off i found a piece of black polystyrene about 2 inches square and 10 inches long it has a number on it 294 000 390 just wondering where it belongs or if its just a packaging piece,if anyone could help with this it would be apprieciated.
thanks
If the ski is a 4tec, you should only check the oil after it's been warmed up
I like to be sure there's oil in it befor i start it. If you check it enough youll be able to figure out what the level is when its cold but good to double check the level once its warmed up and i also like to check it when im done for the day. :cheers:
heres some pictures
hi tried searching for the part number on the brp site no luck with that.hopefully you guys will be able to help,
cheers
sorted now someone called me back from brp and told me it was a packing piece and to throw it in the bin. good job done by whoever did the pdi,
I can see how that'd have been confusing. Glad you got it worked out.
